Can Anyone Help Me Build My D17a To Get More Power Out Of It Without Compromising it Being Daily Driven ?
I'm Done With Down Piping And Headers What Else Do I Need ?Im Looking Forward To Build This For Good Drag D Series Among Lahore
Turbo it??
Staying N/A
Intake Headers Exhaust. Fuel pump, Bigger Injectors.
What Injectors Should I Get ?
Bigger injectors doesn't work without ecu tuning.
Then what u suggest
Get a stand alone and map it according to upgrades like bigger injectors or throttle body.
Stand alone like vafc and e manage ?What else parts do u suggest to make more power while staying and n/a and not compromising Daily Drives
Yes those.You can't build engine right? Then throttle body, injectors, headers, coils and a piggyback to manage that and trick the ecu accordingly. Mapping a stand alone is more difficult.
Which throttle body and what injectors & coils i need ?
Lolz bro I meant to say that if his car has 190CC injectors then go for bigger ones which comes in jdm versions like 240-60cc for D series. Its not like i am saying him to go for 500cc injectors. Those are bolt on and don’t effect ecu map, just bit better response.
Get yourself a K24 swap
It will. It's ecu is mapped for 190cc injectors. Installing 240cc will hurt the mixture. You are not telling ecu that you're changing injectors do you?
