As the title states - what would cause a vibration in the clutch pedal? The vibration is rpm dependant and felt while driving, not shifting. The vibration increases with rpm not mph. If im cruising and i rest my foot very lightly on the clutch pad i can feel a vibration coming from the pedal that increases with rpm. The vibration is in the clutch pedal only, not the floor or other pedal. My mechanic told me the vibration is there because some foundation bolt are broken and to fix the issue he need to pull out the whole engine. please help me URGENT!!!!
NOTE: The car was fine last night when I was on my way to home this happened. I feel some kind of friction in clutch pedal when press the gas.
