Aoa, I need to buy santro front and back bumpers. Can any one tell me the updated price of those (kabli/ used but not repaired). One from Rawalpindi and Islamabad are appreciated. Thanks
Taiwan pair costs about 6k
Got the axle kit replaced for my passenger wheel. The kit costed 1700. 300 for Khiradi and 500 for the labor. Got the heater fixed today aswell. Needed to open the dashboard. The heating coil (don't know the exact name) costed me 3000. 1500 for labor. The heater works great.Can anyone tell me if I can find the cable for moving the switch from cold to hot? The electrician said they don't sell separately and I need to buy the whole box for that cable. Any help would be appreciated.
Add coolant in ur radiator, normally the heater core gets blocked so coolant might help it in keeping it open. Well did u get the heater core new or used? New china one is for 3000 and kabli one for 2500 i think and from whre did u get the work done from? I got the heater working recently and the guy took 2500 and got the heater core from sadat bhai. The old one was all choked up with signs of rust coming out from the inlet/outlet pipe holes
My heater core was leaking water it was a chinese one installed previously. It was for 3K chinese new and I got a Kabli one for 3K from Mithu Khan. I got it done from I14 haji camp road. Took around 3 hours and it works fine now. I'm thinking of shifting to coolant. Just remember to drain your heater core once you want to disconnect the heater in summers. It won't make rust and won't damage the heater core.
AoA sir.How to disconnect heater in summer and any easy way to drain it.
The AC guy said nvr to disconnect the heater. The only way it chokes is when we disconnect it and the slightest water remains inside and u can nvr drain it fully except taking it out. I will keep it as it is with AC and heater both working
This is common practice that ac walas used to disconnect heater pipes to save core from rust.@adilfaridR u sure, some water remained in core yet?
Best way is to use coolant to minimize the possibility of rust
Actually the pipes of the heater core in santro are not straight, they r slightly upwards. The issue is u disconnect a pipe and expect all the water to run out but thats impossible. Spent almost 5 hours at the AC shop so he shared all the info he could during the chit chat session v wre having. Ppl disconnect heater core pipes in summer to increase ACs cooling, still dnt get it why as both the cores are working seperately. The only way to completly drain a heater core is to either take it out or apply some sort of blower which i dnt think can fit in that close area otherwise it wont drain all the water
Bro i asked cng mechanic for adding one more cylinder. He said it cant
Can any one tell me which gear oil viscosity should i use in my santro and how many liter should i add in it.
Please can anyone guide me.Tommorow i am going to workshop for replacing gear oil.also someone can guide which power stering fluid should i add in it.the old one will be drained tomorrow
Bought 2007 Santro club GV. Please comment. How is the ride?
Looks clean. Ma Sha Allah
Your ride looks clean MA SHAA ALLAH. Can you give a detailed overview about the condition and the price if you don't mind.P.S: NEVER REFUEL FROM HASCOL.
Can anyone help me to find the owner's manual? I'm looking for it for quite some time. Any help would be appreciated.
Can anyone tell me the quantity of gearoil in Santro's gearbox?
Condition is good. Odo reading is 161900 km. Engine is genuine, never replaced, checked also engine no. Mentioned on engine block and matched with that of engine number mentioned on smart registration card with help of mechanc. Token is lifetime paid. Never has been into accident, verified car's condition from pak wheels car sure inspection service on payment. Price guess please?
Bought 2007 Santro in good condition. Please comment guys
Gear oil capacity is 2.6 liters, 75w-85 required. Zic or kixx both are best
For steering flood, the ATF Dexron III will be the best, ZIC or KIXX
