Aslam - O - Alaikum!
How is that if I replace the rear drum brakes with disc brakes, my limited knowledge about the brakes pattern of front disc and rear drum is due to the 10% more weight in the front due to engine and balancing of it is the cause of using drum in the rear while clearly disc brake have more stopping power.
Now I have the CNG cylinder in the rear can I assume it is safe to install the disc brakes in replacement of drum in rear without causing any imbalance. I have to replace the front pads as it is now metal to metal contact and pad is completely worn out on one side so I am thinking of doing maximum while replacing those and changing all the old black fluid
