On further assessment i asked the mechanic to change the pipes associated with the radiator as i will be now using coolant instead of water
The water body was in good shape and the radiator was also fine so got it cleaned
Carburettor was sent for complete overhaul as it was running rich and i was getting terrible fuel average also the CNG kit is removed for good along with all the wiring and pipes plus cylinder
Engine mounts of the car were not in a good shape , they were deformed and broken , so will be changing them as well
Timing belt and timing bearing was also worn out so will be changed along with plugs
