I am planning to sell my Alto AGS. Need your opinion, what should be its price?
I keep all my vehicles with love.
Here are the details of my vehicle.
Alto VXL AGS 2019
21,000 km driven
Almost all the time driven in nearby areas. Driven on long once.
Never involved in any accident. No panel/part is repainted.
Bridgestone Nextry made in Japan tires installed.
I work on my own cars and do not compromise on maintenance. I have always used OEM parts only.
Engine oil (Havoline API SP 0W-20) and oil filter (Suzuki 16510-84MA0) changed every 6 months irrespective of the mileage.
Last oil change done in 05-Jan-2024
Liqui Moly ceratec was used during the first 5000 km of ownership
So far OEM suzuki air filter was used, but the last filter was changed with JS Asakashi which is a quality after market part.
Last air filter change: 12-Feb-2024
Denso Iridium Power spark plugs installed on 26-Nov-2022
Last spark plug cleaning done on 12-Feb-2024
Since I was not satisfied with Suzuki's coolant, coolant system was flushed with distilled water 3 times
and replaced with Havoline Xtended Life.
This service was done on Aug-2021. The life of Havoline coolant is 5 years.
Gear oil is changed twice so far with Suzuki Ecstar 75W. Last one was done in 2023.
I forgot to note down the month in my maintainance log.
AGS actuator fluid changed in 21-Jan-2023 and then on 01-Jul-2023. The reason for doing it 2nd time
is you cannot extract all the fluid if you don't have an advance scanner.
Last break service done on 02-Jan-2023. This is a low mileage vehicle, so I do brake service once a year.
Last brake fluid changed with DOT4 on 26 Nov 2023
Last throttle body cleaning done on 12-Feb-2024
Last oxygen sensor and catalytic converter cleaning done 12-Feb-2024
Last fuel injector cleaner used in Mar-2024
