Well. So 4 things are on the priority list:
1) the pcv valve replacement
2) finding that small coolant leakage
3) carburettor choke setting
4) getting heater working
Other than that, if i get time, will work on the proper AC vents fitting. This will require dashboard dismantling so not sure if i should go ahead. Currently all vents work simultaneously so air flow is distributec snd doesnt reach the back seat passengers at all.
Bumper hinges are also not perfectly aligned due to misaligned welding of the metal holder/,guard on the front of the vehicle.
Some other cosmetics include proper fitting of speaker board (i havr the original one but i need to repair it a bit). Also, the rubber boot of the gear lever i need to get it customised by a cushion maker or cobbler as the console box is chinese and the boot doesnt fit properly which disengages the 3rd gear
