We set temperature to 29, 30. But still need to cover up with bed sheet. At 26, we will need blanket
I have realised in many cases the 'set temp' is not the actual ambient temperature. Sometimes the calibration of the AC temp setting is off.
That's mostly when I feel (gree) or follow me(orient) or something like these feature is turned on. Which uses thermostat inside to send temperature to AC periodicallyAnd people enable it mistakenly
I usually set at 28 at night with ceiling fan running at slow speed.
I've LUNAR Orient T3 IoT 1.5 ton with WIFI. But their Monitoring app Mevris is a mess these. Unable to add new devices in their app so I am unable to monitor any statistics.
A lot has to do with humidity, once the Aircon removes the humidity in room it gets comfy. I use daily at 28, works fine
I feel feature and like when enabled use more electricity
i think if outside is like 38-41 degrees than 28-29 degrees inside the room is very comfortable and safe with children.
cooling the room further causes children to start sneezing.
Ok right..I clean them once a season with a normal tap water and not with pressure washer.Ill call them soon may be next week.
4-5 Deg is superb.. The ground portion one never drops below 15deg and the upper portion one always stays between 16 to 18...I doubt that my thermometer is faulty as it does feel cool but if i click on feeling button of my AC remote, it never goes down below 28..it means something is not good.
Right, running a DC fan might help at temps like 28,29. Making it pleasant inside the room.
Without a fan I personally wouldnt feel comfortable even at 27, but I guess everyone is different.
You’re right about humidity. Though in my experience at 27,28 n above humidity becomes quite high inside the room, above 65% which makes me uncomfortable.
What humidity % do you usually have in the room at 28?
I'll get a meter for checking humidity. Presently don't have a reading. But feel is ok at 28 due to dry air.If you are worried about humidity levels, try running AC in dry mode , even at 28 it performs well
Hi all,
Dawlance Mega T pro VS Dawlance Elegance + UV inverter 1.5 ton. Which would you choose and why? Thank you.
@ch.talal
No, It is not only comfortable it feels like jannat
i also have same AC Unit. If i run it at 16 max lower. Still the room temperature will drop only 2-3 degrees at most. Room in top floor 10x10 and totally sealed pack. Now if you think heat is coming inside then the results are still same on rainy days.
what is your room size ?
My ac grill air temperate is 4-5 degree at 16.
Do you think than 1 ton capacity is less for upper floor 10x10 room. Roof and Back wall in sun !
2100ft3/60m3
no it's notit's absolutely fine for your room
Launching next month, comes with 4 solar plates. Price 660K
Like how 60m3??your room is 15x15x10 feet !
its 13x17x9.5
