dude what is the different bewteen d15 4efte3stge help me plz
What kind of difference do you want.
They are from 2 different manufacturers, have different power outputs... You can compare them by using Google ..
D15 is Honda 1500 cc sohc 16 valve engine...... 4efte is turbo charged 1300 cc dohc engine....3sgte is 2000 cc turbocharged dohc engine....and none of them will fit properly into charade 🤣
which of the engine will fit in it \
Depends upon which charade it is.Swap can be done. Swapping 2zzge is better then all these listed.
I found its original cb engine best for daily driving
i want some power in it bro
Drive her on petrol......power hi power..... anyhow I found vitz szfe engine a better swap nowadays....but u have to be careful from high speed breakers....,coz sump is lower than car itself......chances of hitting from below are very high
You can't find that engine in a good condition in scrap yard. Restoring is another debate and yet have drawbacks.
In Lahore all parts for cb engine are available......even original head is available.......the issue is carburetor which can be sort out with mechanical common sense
price
You are talking about bilal gunj? Are you seriously thinking that such an old engine is available in good condition?
Nope replacement parts are available......if block is in good condition ........else everything is available and rebuild can be done
Best of luck.I will prefer new generation engine any day. Old chassis with a new technology engine is my favourite combo.
Everyone is not expert like u.....if this combo fails then it becomes big money pit...
No one is an expert neither i am.If you have the know how of how things work, awesome swap can be done.And 1nzfe in a g100 charade is a pretty good swap.
I have swapped 1sz-fe in 86 charade....4efe in g100.......1nzfe in 86 charade........but a proper swap requires a good electrical work with change if instrument cluster......stiff shocks...... strong cross member.....and a big hub of gttx charade and improved brakes...... otherwise it will compromise on the safety of driver and other people believe me
You had done then you know better. If things are arranged properly, everything works fine.
Along with an experienced mechanic, electrician, machinist and deep pockets.....which are rare item in Pakistan
For me remove these things, i just need deep pocket to do something like this
